Android 11 is draining the battery
jaibalaji2020
Model Name: Asus 6z (Zenfone 6)
Firmware Version: WW_18.0610.2101.127
Rooted or not: not
Frequency of Occurrence: daily
Ever since I upgraded to Android 11 the battery is draining very fast. Android System takes up too much battery. I used to get more than 10 hours Screen on Time before and now I get barely 5 hours. I'm also on Power Saving Mode.
Screenshot attached.
22 REPLIES 22
ZT-c2f0d5a4
For me battery backup is good
cw_shop
Update 132 is also not really working.
My Battery still drains 2-3 times faster than with A10.
I have not used the phone, but the display shows often a status and does not go to sleep
With A10 I had nearly a week before recharge, no every 2nd day!
Update: Seems that a factory reset works. Bad thing, because of loosing all settings...
krewniak19
Rising Star II
it's true, the update only helped a little, as you can see, I don't use the phone much, the applications are also low in percentage and the battery goes down like a dragon
