Android 10 BUG . Can't open display in settings.
shiv1g
Rising Star I
I recently updated to Android 10 and I'm not able to open display settings in settings app. It keeps crashing.
16 REPLIES 16
khizratiq
kikoly
The current short-term solution is as follows: Drop-down menu > Edit > Add "dark theme"; After the new addition is successful, you can resume normal after switching once.
https://zentalk.asus.com/zh/discussion/12483/%E6%9B%B4%E6%96%B0%E5%AE%89%E5%8D%9310%E4%B9%8B%E5%BE%8...
Worked for me.. thank you!
_jis_
Zen Master III
Worked for me too, thank you!
baum
I had the same problem!
Adding dark mode to the drop-down menu fixed the bug. I can open the setting for display now.
eyal_tropen
Same here. Crashes...
_jis_
Zen Master III
eyal.tropen
Did you noticed that solution is already present right in this thread?
