08-25-2021 01:29 PM
08-29-2021 11:49 AM
08-29-2021 12:10 PM
piivikkiYes, your device is up to date but did you try this?👇👇I think I should have network issues all the time if it was a hardware problem, not only during calls. It sounds like you have a different problem than me.
08-29-2021 04:12 PM
08-30-2021 04:33 AM
piivikkiYes you can give a try with factory reset but also i would again suggest you before factory resetting ur device first you should try with another SIM which has Volte service enabled to check on that matter.Yes, I've removed and re-inserted the SIM cards, several times. Even tried with another carriers SIM but that one unfortunately doesn't have VoLte service so it doesn't say that much though. Internet doesn't disappear during calls though.
Each individual SIM slot has 4g+ network (with my carriers SIM) practically all the time except when it disappears during calls.
I might factory reset my phone one of these days and see what happens...
