04-07-2021 10:40 PM
05-09-2021 01:16 AM
Christine_ASUSThis issue wasn't there before, it occurred after latest march update, u all put bugs after updates n u all know very well that most of the 5z is not under warranty, so why to spend bucks for the issues u all pushed.Hi friends
Thank you all for your reply. Please note that double tap functions highly involves hardware support. If the functions are not as sensitive as before, kindly bring your device to the nearest repair center for hardware checking.
Does "double tap stops react after long time using" appear in any specific app? Please put the behavior under observation. Because I can use double tap to suspend & to wakeup properly, if you encounter this issue, please wake up double tap function by pressing the power key and check third party app disturbance.
05-20-2021 02:11 AM
