04-07-2020 01:40 AM
04-24-2020 07:36 AM
Anders_ASUSHi,https://zentalk.asus.com/en/discussion/comment/74017#Comment_74017
4K 60fps playback is a separate issue which we're already investigating. The recording is smooth if you play it on a computer but the playback on the phone is stuttering.
The GPU is not under clocked to my knowledge. Unless the people from telegram who found this, can come over here and tell us exactly which app/method they were using. It's probably as someone else here said, that their device was not rooted and because of this, the tool could only show the minimum clock
04-24-2020 08:13 AM
bharanivijay69Can you show any Snapshot? Details recorded while recording PUBGm performance session?https://zentalk.asus.com/en/discussion/comment/74058#Comment_74058
Iam the telegram user whom you wanted to share the method. I used Snapdragon Profiler. It shows realtime CPU,GPU,RAM usage and much more. I found that while playing PUBG which is a high graphics hungry game,the GPU frequencies are only in the range of 50-150MHz(Rarely 200MHz). While on antutu GPU test the GPU frequencies are above 400Mhz and touches 600 MHz sometimes.
I have mentioned Antutu GPU stats just to show that the GPU in 5z can reach higher frequencies.
I couldn't share the above said stats video links because Iam a new user.
Thanks.
04-24-2020 08:16 AM
AbhinavI screen recorded the realtime usage in my PC. I can PM you the video link if you want to see.https://zentalk.asus.com/en/discussion/comment/74691#Comment_74691
As the profiler application records everything.
04-24-2020 08:24 AM
04-24-2020 08:41 AM
bharanivijay69[Content of the .docx]https://us.v-cdn.net/6031231/uploads/115/XVT78WKERZRC.docx
Hope this helps.
