04-07-2020 01:40 AM
04-20-2020 04:27 AM
04-20-2020 04:37 AM
AbhinavEIS FOR 5Z cannot be better than oreo it was cherry on top for 5Z but in pie it was bit degraded and in A10 its totally worsehttps://zentalk.asus.com/en/discussion/comment/73010#Comment_73010
Did you noticed that 4K 60fps video encoding and decoding both are choppy and laggy due to under clocked GPU.
It's not smooth anymore. This means Battery is getting saved but at the cost of smoothness. "This is not acceptable".
"A weaker GPU is causing laggy game play, Chopoy 4K 60fps video encoding as well as decoding and so many things".
How can Android 9 (.111) be both high performer while gaming at the same time good at battery too. On A9 I never faced any choppy 4k 60fps Encoding and Decoding Issue.
Not only 4k 60fps but With Main sensor the videos with EIS is also very Jelly like. Whole video wobbles like water effect at corner of the videos. Please check yourself too.
@sidarya31 he had also noticed the same issues.
04-20-2020 07:19 AM
amitgarde3Stock Android (non root) doesn't give permission to any app to read GPU frequency that's why GPU frequencies remains lowest. You have to root your phone to know the GPU load. Try doing the same in rooted device.https://zentalk.asus.com/en/discussion/comment/72822#Comment_72822
I used app called profiler for battery,ram,CPU LOADS n frequencies but was unable to get GPU in my app
But other 2-3 user from telegram group that guysz discovered that GPU is at limited for stock device is unable to boost let me share u screen recorded link those guysz shared u can see GPU is limited to 257 there and even cpu frequencies cn be seen in video plz check guysz @ValeeraSanguinar @brunoferreira.retry@gmail.com @Abhinav @Averan @bharanivijay69
They also said in many other devices ususally cpu frequencies are medium while GPU boosts up but in 5Z cpu is boosted where as GPU limits itself very dissapointing this is check below video plz 👇
https://us.v-cdn.net/6031231/uploads/738/7JN33YSCZ72K.mp4
For custom rom this is In lobby GPU is 530 see below screenshot
Hope for fix as soon as possible and mods to confirm why is it so?? CPU-Snapdragon 845 GPU- ADRENO- 630, where is justice?
04-20-2020 07:56 AM
amitgarde3"sad" 😥https://zentalk.asus.com/en/discussion/comment/73240#Comment_73240
Hopefully i wish lot more updates yet to come until support ends n may be system will get stable with last update that will be in november (lots of problems to get fixed) i guess, but 5Z is still not stable in A10 we can do nothing than to wait for stability updates 😞
04-20-2020 08:56 AM
Chintan DevganiyaAlready shared screenshot of Gpu frequency of rooted custom rom user it is 530 n thats the diffrencehttps://zentalk.asus.com/en/discussion/comment/72936#Comment_72936
