04-07-2020 01:40 AM
04-22-2020 07:24 AM
Anders_ASUSThank You sir. 🙏I've found the touch issue and will ask our devs to fix it. Thank you for your help!
04-22-2020 07:51 AM
sidarya314K 60fps playback is a separate issue which we're already investigating. The recording is smooth if you play it on a computer but the playback on the phone is stuttering.https://zentalk.asus.com/en/discussion/comment/74015#Comment_74015
What about lagging and frame drops in 4k 60fps videos sir? Its really annoying please do fix this issue. And according to above posts i came to know that our GPU also got down clocked.
04-22-2020 08:58 PM
04-23-2020 01:06 AM
Anders_ASUSIf this is the case that GPU is performing at it's default configuration then please see those minor Stutters which we face while scrolling within UI, in Settings, while getting back to last window, In Facebook Lite app, WhatsApp, everywhere.https://zentalk.asus.com/en/discussion/comment/74017#Comment_74017
The GPU is not under clocked to my knowledge. Unless the people from telegram who found this, can come over here and tell us exactly which app/method they were using. It's probably as someone else here said, that their device was not rooted and because of this, the tool could only show the minimum clock
04-23-2020 07:41 AM
AbhinavSlow stuttering scrolling in "show all system apps" is normal Android behaviour and not a bug. When Google make it smooth on their Pixel, we will get it too eventuallyhttps://zentalk.asus.com/en/discussion/comment/74058#Comment_74058
Even while scrolling frame drops can be seen. Scrolling and System UI animation is little bit jittery.
(Just Open All Apps option within Settings AND press "show all system apps" and then scroll down a bit faster you'll definitely going to see UI frame Stutter, the same frame stutter can be seen within scrolling "Auto-Start Manager" just keep ample amount of apps let's say at least 30 apps.
