Idle battery drain
janmykel
Model: ZE620KL
RAM: 4G
Firmware/APP Version: Pie
Frequency of Occurrence: Always
Rooted: No
APP Name:
Hello guys, I would like to ask if my battery is acting normal on the new update? I feel like it's draining my battery quicker than when I'm on oreo. I left my phone once after the pie update at night at 26% then i woke up having it in 9% even in idle state it's draining crazy. Pls help is this normal?? (I accidentally manual updated my phone after the FOTA gave me the update :-() Thank you.
ServiceE_Asus
Hi janmykel, Good day. Are your firmware version currently on the latest WW-V16.0610.1812.58? If yes. I would suggest you let the battery charge more than 30 minutes even the battery percentage shows 100, then remove the cable before going sleep. Please show me 2 screenshots as below on next morning before you use the phone. 1. Battery: settings> Battery (Battery usage since full charge) 2. Battery usage: settings> Battery> please click the big battery icon :battery: Thank you.
