Battery drain Fastly
aanujkumar12332
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
Asua zenfone 5z
zs620 kl
No rooted
Battery Drain fastly when received updated 5 august update veesion my battery drian automatically 20 to 25 % in night and backup is not more sufficient as compared old
5 REPLIES 5
aanujkumar12332
Plz asus fix this problem battary drain fastly and backup is not more sufficient as old days
victor010
Zen Master III
Hi, please follow below steps may improve battery backup:
1. Close apps that are not used (Bluetooth, WiFi, GPS, etc.)
2. Adjust sleep time and brightness (Settings > Display)
3. Boost memory when you see memory consumption is high with no app running,
4. check for background running applications, stop/disable unwanted apps, you can manage apps from auto-start manager.
you may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/Indi
hkorkut
Rising Star II
the battery is still draining rapidly. it's a software problem and you still say factory reset. Please fix this software problem now
aanujkumar12332
hkorkut
hiii i m not gotted latest update which release date 17 September
you received update or no plz tell me?
