Battery Drain Drastically
srahoul247
Model: ZE620KL
RAM: 8G
Firmware/APP Version: Android 10
Frequency of Occurrence: Regularly
Rooted: No
APP Name: Battery Drain
Dear Team, After receiving the android 10 update it's been an issue that the battery Drain Drastically on normal ussage. I'm receiving only 2 hours of screen on time on my normal daily usage and in airplane mode also it is consuming 10% of battery where in android pie i was getting 4-5 screen on time and getting battery drain in airplane mode of 1-2%. Kindly update with security patch on very urgent basis and i also think that every 5z user has the same issue.
I'am also facing same issue with my battery performance of asus zenfone 5z. it gives roughly around 2 hours of screen on time and also facing battery heating issue on little bit of heavy used. i'am requesting please resolve battery problem and also make android 10 stable.
