07-15-2020
11:49 PM
- last edited on
01-16-2024
12:58 AM
by
ZenBot
07-16-2020 01:08 AM
aspectlastaTry to press a bit charging port portion and see if charging starts or not coz after your description as vibration can show charging for few minutes this shows that vibrations creates some movement in port connections and due to which i can be somewhat sure that connections are loosen up on charging port and this can only be fixed with changing your charging port or refixing connections on board with charging portI know its strange but when I call someone and put it on my ear i.e when proximity sensor works, it vibrates and notification light turn on indicating it is charging where sometimes it actually starts charging but sometimes it is just a show.
Factory reset is the final option that's why I am looking for other methods to fix this problem.
Thanks for your concern.
07-16-2020 01:27 AM
07-16-2020 03:20 AM
aspectlastaDid you drop ur device? As i said above connections seems to be loosen up of port n board this cn be easily fixed by service centreYes I did that and nothing happened. I moved the port up-down, left-right holding it tightly. I also made sure charging port is working correctly.
I did few experiments and found that charging works when I press screen. Not sure why this is happening.
07-16-2020 11:37 PM
07-16-2020 11:40 PM
