11-30-2019
09:11 AM
- last edited on
01-16-2024
01:40 AM
by
ZenBot
12-04-2019 01:27 AM
mauricio_b.t posted on 2019/12/4 03:03 The only problem i'm having os related to memory management. It closes apps in background, alot ...I do not see a problem in this respect. To my understanding: Android 10 is faster in starting an App than previous versions of Android, it is therefore normal and good that it closes Apps in the background if they are not in use,. Also, the usage of the Random Access Memory that you see, should be somehow an average usage, some margin must be left, otherwise the processor would remain stuck. (this information is not like the one of a Windows PC where you can see the instantaneous usage of the RAM)
12-04-2019 07:17 AM
12-04-2019 07:19 AM
12-04-2019 09:11 AM
domsotv posted on 2019/12/4 16:19 Soo.. Android 10 fix problem with camera low performance in low light?Hello, in my opinion it did improve, but it is better to wait for more influential opinions, Matteo
12-04-2019 01:28 PM
Bruno~xD posted on 2019/12/1 23:09 One of the issues described by Asus about A10Q is that some apps aren't optimized yet. Do Zenfones ...I think I found solution for low SOT. I turned off in menu Facebook App Installer, Facebook App Manager and Facebook Services. After two days and two charge I can easily obtain 5,5h SOT.
