5Z Update to Android 10 - a couple of little problems s...
srota
Rising Star I
Model: ZE620KL
RAM: 6G
Firmware/APP Version: ww_100_04.44.98_20191115
Frequency of Occurrence: once
Rooted: No
APP Name:
Last edited by srota on 2019/12/1 12:20 5Z Update to Android 10 - overall good results, a couple of little problems solved. Just to share some findings , in case other users will encounter the same little problems. I updated the phone downloading the Android 10 version ww.100.04.44.98 from the AsusTek web link: https://dlcdnets.asus.com/pub/ASUS/ZenFone/ZS620KL/UL-Z01R-WW-100.04.44.98-user.zip The updating process went smooth. Problem with Contacts: when the phone restarted I noted that opening the contacts, names and addresses were not visible. Moving to the dark background and moving back to the light background, names become again readable. Problem is solved. Essentially color of the fonts beame initally white on a white background, characters were no more visible. Problem with SD card . After the upgrade, the SD card was recognised, with all the files in it well readable in the Data Manager . Following a phone reboot the card was no more visible in the Data Manager. Rebooting again the phone, the card became again visible. Currently no problem with SD card. Few issues with Widgets: it seems to me that few Widgets are not working well, perhaps it is a matter of learning from my side. No big issues in any case. Microsoft Apps all working, very well: I have installed Edge, OneDrive, Outlook, Office, Microsoft Weather : all work fine, very fast. WhatsApp: working very well. That is all from my side.
66 REPLIES 66
Y_ASUS
Zen Master I
Hi all, A new firmware update version WW-100.10.107.46 has been released. The camera not showing photos problem has been improved. You may update to the latest firmware version by checking in Settings > System > System update. Thank you for waiting and have a nice day 🙂
Y_ASUS
Zen Master I
Hi all, A new firmware update version WW-100.10.107.46 has been released. We have improved the problem of no HD in Netflix. If the problem is still appearing, we would suggest that you reinstall or clear cache&data of Netflix. You may update to the latest firmware version by checking in Settings > System > System update. Thank you 🙂
