11-30-2019 09:11 AM - last edited on 01-16-2024 01:40 AM by ZenBot
12-29-2019 01:12 AM
12-29-2019 06:24 PM
Dheeraj09 posted on 2019/12/28 23:45 Guys need help. When i updated to android 10 from android 9, everything went smooth for few days and ...You may check the downgrade file on their website: https://www.asus.com/Phone/ZenFone-5Z-ZS620KL/HelpDesk_BIOS/ Please note that the data will be cleared after you downgrade. 1. Download the firmware to internal storage. 2. Remove Google Account (Settings > Accounts > Remove). 3. Restart the device and accept the terms of the notification that will show on screen.
01-09-2020 06:46 PM
Dheeraj09 posted on 2019/12/29 10:45 Guys need help. When i updated to android 10 from android 9, everything went smooth for few days and ...Hi Dheeraj09, Is the problem still appearing? What are the apps that have this problem? Thank you 🙂
01-09-2020 06:48 PM
ekalavya1490 posted on 2019/12/29 17:12 Same issue here, the phone was perfectly fine before the update , after the update the , the backup ...Hi ekalavya1490, Could you tell us what you mean by "backup has reduced by more than 50%"? Thank you 🙂
01-12-2020 01:17 PM
Jei_ASUS posted on 2019/12/24 12:43 Hi amitgarde3, We are looking into the problem. Sorry for any inconvenience caused.Also screen recorder does not record internal audio from whatsapp video call even after setting record audio option to internal audio new bug found :Q and can we know what about december security patch n other bug fixes with battery optimisations for A10 ??? :'( is anything cooking for 5Z or juz 6Z and ROG 2 are the lucky 1nce to get fixes?? :@
