Zenfone10 Front Camera Problems
Lotus1
My front camera wont work after the latest update including other apps that used front camera like instagram. How can i fix it?
#zenfone10 #camera
1 ACCEPTED SOLUTION
Accepted Solutions
Lotus1
Update : The Problem was solved after i went to the service center, they changed the camera & now its working.
8 REPLIES 8
kikoly
Hall of Fame II
清除相機的儲存空間與快取無效的話,會叫你送去服務中心檢測。
Ive used Google translate for this, sorry if there's a mistake. I've already cleared the cache, even went through factory reset my phone and the result still the same. The smmi test also  crashed after testing the front camera.
Build number : WW_33.0220.0220.43
kikoly
Hall of Fame II
Please take your phone to a service center near you for repair. If you need official help, please go to the English forum.
  • Thx u for the replies, since I don't know which one is the English forum I just go through the first zentalk forum that popped up in google, Also thanks for the advices
