Wireless charging not worka
Wtark
So, yesterday I saw a notification about a new firmware version, also an update to android 14, downloaded, updated
After the update, I saw a notification saying that the component firmware is being updated and wireless charging is temporarily unavailable.
In the end, the notification disappeared, but the ability to charge wirelessly - no.
Apparently, it used to be.
Should I wait for the next update, or can I try a factory reset?
I couldn't find a way to roll back the firmware, unfortunately
4 REPLIES 4
janarosta
Hi, will you able to share your opinion on the new android14? What else is not working after the update.
averysen
Same exact issue with mine after upgrade to 14. Same notification. Wtf?
janarosta
Ok. Look like a common issue then on Android 14. I'm very tempting to upgrade but this is very let  down👎. Asus, please do better. At least on acknowledging it upfront.
averysen
Update: shutting down my phone and restarting seems to have resolved the issue.
