Wifi problems
Damienfr
We have 2 Zenfone 10 at home and their a same problem : Wifi is correctly connect (see files attach)  but no connexion with my local cameras  and web. Others wifi equipments on my lan works perfectly (phone and latop). Gateway and dns adress are correct. I reboot same problem.
 I create log with bug reporter. How share the WiFi log ?
Thanks
Mansi_ASUS
Hi @Damienfr,
I'll send you a DM, you can share the log there.
