Randomly, animations get choppy, unlock gets slow and battery drains faster
HoobleDooble
Hi. Ever since I've had the phone, animations will randomly get choppy and slow, particularly when opening apps, and at the same time the phone will be slow to unlock (a few seconds) and the battery will drain faster. I am on 120hz refresh rate, but it doesn't make a difference what setting I choose. Restarting fixes the problem, which implies I suppose that it could be related to an app, but I have no idea how to verify that without resetting the phone and reinstalling apps one by one. Any ideas would be welcome. Thanks.
EDIT: I should mention that I compared running services during times when the problem was or was not occurring, and I couldn't identify any which were only present in one scenario and not the other.
Mansi_ASUS
Hey @HoobleDooble,
Can you please share your phone's serial number along with a log file?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
