- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-03-2024 08:40 AM
Here in italy my carrier does send me an SMS for each missed call so I have the smartphone on my desk and ~80% of the calls are missed by default almost immediately because I also have the timestamps in the missing calls in the notification SMS.
I just can't work like this knowing I'm missing most of the people that try to reach me(I've a business too).
The smartphone isn't in "Airplane Mode" or "Do not disturb" or "Silence" modes and this happen and drives me crazy.
How can I try to solve this issue?
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-04-2024 03:44 PM
Just disabling 5g wont change anything, you have to disable also 4g, because without volte Phone uses 2g or 3g for calls, not 4g.
The bad news is also this is not the solution, because if you disable 4g, you wont be able to use mobile internet. Its just to test if cals are working correctly when Phone is forced to use only 3g all the time. If yes, then you might need to contact with your carrier, or maybe Its a software problem in the Phone after update (i dont think so).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-04-2024 03:59 PM
Ok, gonna try with 2G/3G alone for test
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-06-2024 06:32 AM
Hey @thepra,
Can you please mention the name of your network operator?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-06-2024 06:38 AM
It's Fastweb, which advertises 5G coverage of my city to, but I've never seen the 5G mark in the top right corner
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2024 02:20 AM
Ok, I tried like that and so far there was no difference, random calls went missed and the other did ring and engage as usual.
I'm frustrated...
