microphone issue
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-22-2024 06:14 AM
Hello,
During calls, my interlocutor sometimes hear my voice very low or even don't hear me at all, like if the mic was muted. Is it a known problem ? Is it since the last update ?
Thank your for your anwser
best regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-26-2024 02:09 AM
Hey @iL2DF-neo.
Does this issue occur while using a specific app?
Can you share a log for the issue?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording”
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-23-2024 06:01 AM
Hello,
I did what you were telling me. The files is 2 Go, is there any specific and lighter files to upload ?
several times, when i wanted to open the sim tray, i put the put inside the hole of the microphone, is there way that i damage it ?
Best regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
04-26-2024 02:58 AM
here is a link to the log i uploaded : https://drive.google.com/file/d/1Q_0KQoe-lrJwqRZi2uzwSCWBFIRxKprB/view?usp=sharing
Request me the right to get access, thank you
