Automatic data connection switch during call
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-01-2023 10:08 AM
Hello everyone,
until recently I owned a Zenfone 8 which had a very useful function in the SIM settings, i.e. the possibility, for using 2 SIMs with voLTE active on both, to automatically switch the data connection from one SIM to the other during a call. Example: if I have set the data connection on SIM 1 and I call with SIM 2, this function allows to automatically switch the data connection on SIM 2 in order to continue to have the data connection during the call.
Now I have a Zenfone 10, updated to the latest firmware available (without root), and I can't find this function anymore, with the consequence, going back to the previous example, that the connection drops and I don't even have the possibility to switch manually because the appropriate toggle cannot be selected during a call.
Why was this option removed? Couldn't it be included in a future update for the Zenfone 10?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-02-2023 11:49 PM
I think this option is available in settings - internet - SIM 2 settings - Data during calls
Regards
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-03-2023 03:15 AM
This function that you say partially solves the problem because it only works if the data connection has been activated before making a call. If, on the other hand, the data connection is not active and I start a call, this option does not work. Referring to the example I gave before, if I have the data connection active on SIM 1 and I call with SIM 2, with the option you suggested active, the data connection automatically switches to SIM 2, but if before making the call with SIM 2 I do not have the active data connection on SIM 1, once the call starts, even if I activate the data connection it does not automatically switch to SIM 2. I hope I explained myself well.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-16-2023 08:29 AM
Normally VoLTE should allow the data connection to stay enabled during a phone call even with one sim. If you could fix that you'd achieve the same goal.
