12-16-2023 08:03 PM - edited 12-16-2023 08:04 PM
Hi! I'd like to have the audio focus toggle. I used to have two audio sources at once on my previous android devices. For example, to add a music on background for an audiobook. Or websites turn off my music.
It's a prietty old Android feature. Does anyone know a way to do that?
01-02-2024 04:37 PM
Hi! Did you find out if it is possible to play two audio sources at once (like audio from two different browser tabs, for example)? I'm thinking about buying a Zenfone, but the multi-sound feature is a must-have. I know that Galaxy phones have that feature.
01-04-2024 11:11 AM - edited 01-04-2024 11:13 AM
there is a way to make every wanted app to ignore autofocus. A bit tricky way, but absolutely doable. But in 95% cases we need to control the volume for each app sepratelly. And this can't be just enabled. ZenUI simply is not ready for that.
So, while the audio levels of streams fit my expectations — I can use the feature. But if the video or audobook is too quite — it's not usable with music.
The last hope is to find another music player with equalizer to be able to reduce music's volume. Personaly for me, it's not an option, as I use youtube music streaming🥲
