10-14-2024 12:36 AM
Hi everyone
I have a new Zenfone 10 with android 14, and tried to connect to Hyundai Tucson using Android Auto wireless.
Every time connection failed. I have done car reset and phone reset but it did not worked.
I am pretty sure the problem is from the phone because I can easily connect from a Zenfone 9 with same version of Android and Android auto as on Zenfone 10.
If someone can give me an advice on what to do next , would really appreciate it
Many thanks!
11-15-2024 01:42 PM
Ok, it has happened again: I was on the phone via Android Auto and then the car infotainment crashed after some 2-3 minutes. Reboot of infotainment, 2-3 minutes phone talk, next crash.
I have created a log file as you explained. I was about to upload it but there are information included that I don't think I want to share. (Wifi SSID, used apps and so forth). Which are the bluetooth specific files you need?
3 weeks ago
Coincidence: VW upgraded my car software to version 3.7 OTA. With this version, Andoid Auto works perfectly!
