Android auto wireless for Zenfone 10
LucianStefan
Hi everyone
I have a new Zenfone 10 with android 14, and tried to connect to Hyundai Tucson using Android Auto wireless.
Every time connection failed. I have done car reset and phone reset but it did not worked.
I am pretty sure the problem is from the phone because I can easily connect from a Zenfone 9 with same version of Android and Android auto as on Zenfone 10.
If someone can give me an advice  on what to do next , would really appreciate it
Many thanks!
6 REPLIES 6
Mansi_ASUS
Hey @LucianStefan,
Can you please share the Bluetooth log for the issue.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Bluetooth”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
I am currently having the same issue with a 2024 Hyundai Kona. Older Samsung phone works flawlessly.
Zenfone 10 starts android auto properly when connected via cable, but wireless is unable to connect at all. Car infotainment always says phone not responding. Bluetooth connects no problem, but I assume the wifi connection is causing trouble, as it never gets connected to the car wifi.
I will try to get the log files tomorrow, if they are any help.
Kajj
Hey, any luck resolving this? I have the exact same problem - even the car is also a Tucson but it's not the car as every other android and iphone connects without issues.
Kennung1
I have (had?) the same problems. Volkswagen ID.3 Pro S (2021) with 10" head unit. My phone is on Android 14, firmware build UKQ1.230917.001.34.1004.0204.201
I enabled developer settings and played around there a bit.
- activated wireless certification
- changed to Bluetooth AVRCP 1.5
- maximum number of connected Bluetooth devices: 1
Also, for the standard USB configuration I changed from "file transfer" to something else and then back to file transfer.
Since I did that, I didn't have a disconnect, yet. But it's only two days ago (300km) that I changed the settings. Maybe someone else can try and confirm?
(Oh and maybe I was just lucky that the error didn't fire in the last two days)
