Zenbook Duo usage with a Linux Distro
Anonymous
Not applicable
if you are using a linux distro on your zenbook duo, can you list some of the problems that you may have encountered?
Second screen working/not working
touch working/notworking
wifi/bluetooth working/notworking
batterylife good/bad
any other component working/notworking
dedicated gpu working/notworking
gamb1t18
I am using PopOs 22.04, and have been using it for about a month. As far as I can tell, the fans work, which was an issue I had read others have had. I haven't figured out how to change the 2nd screen's brightness which also seems to be a common issue with linux distros. Other than that, I have not run into any issues or noticed any others.
Anonymous
Not applicable
Yes i am worried what kind of data asus is gathering from the second screen and looking for a linux distro too
ASUS_Bot
Rising Star II
