02-28-2020
11:35 AM
- last edited on
01-16-2024
01:24 AM
by
ZenBot
03-20-2020 03:49 PM
liviu.daniel posted on 2020/3/20 03:28 Same issue here. What I did was to uninstall the driver completely, restart, scan for hardware chang ...That didn't work for me. I uninstalled everything, including Realtek Drivers. I even went and cleaned the driver store with all the stuff installed part of the package. Restarted and scan for hardware changes. Intel Smart Sound Technology SST OED and Audio Controller were not found. This is expected because the drivers do not seem to be distributed part of Windows. The fact that yours got added with an old version strongly suggest you had an old version lying around in your driver store. So yes reinstalling from scratch with the current BIOS and available drivers from Asus website is not possible. I used this to clean up my driver store : https://github.com/lostindark/DriverStoreExplorer. Super useful.
04-01-2020 10:59 AM
04-07-2020 10:15 AM
04-18-2020 02:29 AM
darktears31How did you installed it? I tried as well, but the extension is .cab.Thanks noel_prg_la1979.
I've picked: 10.23.3406.200 and it solved the problem for me. Asus should update their driver page, clearly the version posted doesn't work with either the new BIOS or newer Windows.
04-20-2020 09:14 AM
