Audio delay on ZenBook 14
XMarksTheSpot
System: ZenBook 14
Battery or AC: Both
Model: UX425EA
Frequency of occurrence: Always
Reset OS: No
Screenshot or video:
Detailed description: There is a very slight audio delay when audio enhancements are enabled. It is quite noticable when doing video editing work. I have found only the Films & TV app does not have this problem. If I disable audio enhancements, the audio is perfectly normal. I have all the latest drivers installed. Is this expected or is it some driver issue?
Blake_ASUS
Community Legend II
Hello ahnafm,
What kind of speaker or headset are you using?
Can you share 1 app that does not have the problem and 1 app that has the problem?
Thank you very much.
XMarksTheSpot
Blake_ASUS
Hello ahnafm,
Films and TV app doesn’t have this problem. But programs like Microsoft Edge and VLC do.
Blake_ASUS
Community Legend II
Hello ahnafm,
What kind of speaker or headset are you using? built-in one? cable headset? bluetooth?
and can you share a video record of the issue?
