Max upgrade N6506MV-MA032W (ASUS vivobook pro 15 OLED)
aliiiii5
Hello everyone.
I was looking to buy the ASUS vivobook pro 15 OLED which currently here was on sale. Only thing is that it 24gb RAM. 16GB+8(soldered). But there was nothing regarding max ram to be upgraded to. ASUS's website says how much ram you can have depends on the specific model but its hard to find. Does anyone know how much ram you can upgrade? Up to 32? 40?
Thank you in advance(:
Falcon_ASUS
@aliiiii5
If you see that the specification for purchase is 24GB of memory, then that is the maximum supported. One of the memory modules is soldered onto the motherboard and cannot be replaced, while the other replaceable memory module supports up to 16GB. Thank you.
