if i install 4+8 can i get full 12gb ram performance?or i will get 30% less performance for using 4+8?
i mean if i use 4+8, will it use dual channel?
if i want to use dual chanel what shoud I do?..
you told in previous comment that if i would like to ran dual chanel i have to install same size ram...is it mean,if i install 4+4, it will use dual chanel?if i install 4+8,it will use singel channel that means 30% less performance?
please answer for last time.
