After the recent 2007.27 update my device drains a lot of battery while gaming. And I can also find noticable drain without gaming as well. Please help me which ks causing the issue . I'm not even getting 5hrs of screen on time . Help me . And there is warranty for my device , if I want to change the battery pack will it be covered under warranty ? Will this issue be solved after the battery replacement ?
