Problem with right Air Trigger
gonzaaa_92
Rising Star II
Hey!
So I'm having a problem with the right Air Trigger of my ROG 2. What happens is that it has some sensibility issues, sometimes you press it and it flickers. Something I noticed and this only happens with the right AirTrigger is that if you force press it, it stops from working. Whats going on?
Thanks!
60 REPLIES 60
gonzaaa_92
Rising Star II
Anders_ASUS
https://zentalk.asus.com/en/discussion/comment/39407#Comment_39407
Just to make sure you don't have the same issue. Please study this video https://www.youtube.com/watch?v=ePi-3DBNM2Q
No, what I'm facing is not like that. To start, I don't use my phone with a case. The right air trigger starts to flicker and to stop working properly only when I apply pressure to it with my finger (something that as I showed on my video, doesn't happen with the left air trigger).
LP_ASUS
Community Legend I
gonzaaa.92
https://zentalk.asus.com/en/discussion/comment/39592#Comment_39592
R&D is investigating solutions, but they did make a suggestion in the meantime. Can you try changing your sensitivity from 1 to 2? We have a feeling that might be a band aid for the issue in the short term.
gonzaaa_92
Rising Star II
LP_ASUS
https://zentalk.asus.com/en/discussion/comment/39673#Comment_39673
Thanks for your suggestion. I tried changing the sensitivity between various values (including values 1 and 2) but the problem persists. Whenever I start increasing the pressure applied to the right air trigger, the button starts to flicker and stops working correctly.
However, nobility forces us to say that if I set the sensitivity at a very low value, the problem is not so serious since I'm too far away from needing to press the air trigger hard enough to make it flicker. But in itself it doesn't fix the problem.
kchinnavigneshr
Rising Star II
Happens to me everytime I start the game. Just pull GameGenie toolbar, open AirTriggers , turn them Off and On. It just goes away.. Have to do it every time I launch the game.
gonzaaa_92
Rising Star II
kchinnavigneshraja
Thanks for your reply, but it didn't fix it for me.
