Network and Wifi Connecting and Disconnecting While Using
agsiglos27
When im home im connecting to wifi and using it for longer period for browsing and everything. The problem is it will diconnect then like 2seconds reconnect again. Same goes with the network when im using 4g. Suddenly it will show no signal on both sim cards then for 2s it will reconnect again. And it keeps annoying me. Thank you for your help.
12 REPLIES 12
Gustav_ASUS
Community Legend III
Are you running the latest firmware version? (17.0230.2004.60)
You can try resetting by going to:
Settings -> System -> Reset options -> Reset Wi-Fi, mobile & Bluetooth
Mention me in this thread if this doesn't solve your problems.
agsiglos27
Gustav_ASUS
Im currently on android 9. Is that the latest version? But i already resetted the wifi,network and bluetooth. Im just monitoring it now if it will happen again.
mortimasyo
Gustav_ASUS
agsiglos27
Gustav_ASUS
Hello. Tried to download the latest firmware and move it to internal storage. But i didnt get an update launcher for me to proceed with the update. Thanks
