Need ur help to get 90fps to pubg
nasrmhan
Hi all. As it turns out, so many devices are still not supporting the 90 fps option on mobile.
What I want from you is to join pubg mobile discord server and send the same as my screenshot and hopefully they can do it.
All other players are doing the same
arpitgenius
Rising Star I
Well 90 fps still not officially pushed to ROG 2 by PUBG...
But you can play 90 fps using hex editor. In fact it lets you enable 90 fps not only on smooth setting but also on Balanced, HD, HDR and even on ULTRA HD for Erangel. So use HEX editor. I have been playing on 90 fps on ROG II since 10 months. NO issues at all.
