01-13-2020
02:19 PM
- last edited on
01-16-2024
01:31 AM
by
ZenBot
01-22-2020 11:56 AM
Anders_ASUSOk, I have tested with the default "all apps" option but the behavior is the same as before.And what if you switch to default "all apps" does it work then?
01-24-2020 07:46 AM
01-24-2020 07:49 AM
03-24-2020 03:51 PM
Anders_ASUSI've updated to Android 10 but the bevior is the same: LED on the back won't blink for notifications unless the phone is charging or the Aerocooler is attached. And same as before checking the screen without removing the notification then turning it off will cause the LED to start blinking.ok, normally I would want to log your phone but we're so close to Android Q now and all developers are away for Chinese New Year so the best thing right now is to wait for the FOTA (which I can't say when) and see if the issue is still there. Probably not since it's working for me.
