01-13-2020 02:19 PM - last edited on 01-16-2024 01:31 AM by ZenBot
01-21-2020 02:16 AM
01-21-2020 02:20 AM
01-21-2020 02:32 AM
Anders_ASUSYes I have, because it's the only way to set specific colors per app, but all the apps I mentioned and tested were added there.One last check before I bother them. Have you enabled notification "Customization" for specific apps in our system lighting settings? If you have, then it will ONLY send notifications to the apps you have customized for
01-21-2020 02:49 AM
01-21-2020 02:50 AM
Anders_ASUSI will test this tonight and come back and report the results.And what if you switch to default "all apps" does it work then?
