12-02-2019 06:38 AM
12-07-2019 11:26 AM
OPCThat sounds great. Can you please share your battery stats screenshots?Battery life I get is amazing. No other phone I had comes close. Coming from Apple and Samsung, Rog 2 in this department beats them up to 4 times longer (Note 8). Once I took it off the charger at 5.30am went on a business trip across 3 countries, phone connected to my car for 7-8 hours over Bluetooth, talked in roaming over 3 hours, checked all emails and used Google maps to find hotel in the evening. At 10pm the battery was at 69%! No other phone comes close to that. In these conditions Samsung needs recharging at 5pm at latest. Note 8 at 1pm ( my personal experience!). This is the first smartphone ever I had that doesn't need to be plugged in my car's charger during the day. It's a real relief and a deal-breaker as I travel for work a lot. Pity for that VoLTE issue!
Hoping it could assist you in achieving the same amazing battery life, here is the summary of what I do as my routine.
1. I did the battery calibration as described in the manual before I started the phone for the first time.
2. In Battery department in settings I have activated all saving options, like detecting apps running in the background and so on. My screen is set to 120Hz refresh rate (the only thing not in saving mode).
3. Overnight charging is set between 23pm and 7am. I wake up at 6.30 and I see the battery is not fully charged. Obviously the system is protecting the battery and it prevents it to be fully charged! No risk in overnight charging if the charging period has been set in Battery Care settings! I can then leave it on a charger until 7am when it will be fully charged, or take it off the charger, typically at 86%. I put it on the charger overnight only if the battery is 10% or lower.
4. If it wasn't on a charger overnight, I do as Jetjosh does. Never let it charge completely (normally to 95%). Or if it charges to 100% take it of the charger immediately.
And that's it! Hope you will achieve the same level of battery performance and personal satisfaction!
12-07-2019 01:19 PM
12-07-2019 01:25 PM
12-07-2019 01:45 PM
12-11-2019 06:29 AM
