High temperature / CPU usage / battery drain on 2009.47
jasonwch
Rising Star II
Model Name:
Firmware Version:
Rooted or not:
Frequency of Occurrence:
As many posted on the forum. I and everyone have similar issue. (This is already upgraded for whole night and a full charge)
CPU also peak at 2.84/2.96 as from Armoury Crate even didn't do anything
Temperature goes high
Battery drain quickly
"Android System" also taking all battery usage from Battery page
What I observed:
From running processes, "Google Play Service" always show up, which not the case in old firmware
What I've tried to fix:
Wipe data (all data not just cache) for Google Play service and Armoury Crate. After cleaned, seems the CPU back to 826Hz, but after I restart the device, it go back to 2.84/2.96 all the time
There may be something wrong on this?
266 REPLIES 266
ronald1985
Community Legend I
Riaan
So wait, to fix this problem am I supposed to disable Google Play Store.if so then how will I install new apps
When you want to install apps, you can enable it and then when you are finished with it, you can disable it again.
It is not ideal but it's to help your device from heating and high on CPU.
Melqui
Can I back to first A10 released (I don't want to lost data)?
https://androidfilehost.com/?fid=8889791610682901159
https://www.getdroidtips.com/asus-rog-phone-2-stock-firmware-collection-back-to-stock-rom-flash-file...
I don't think you can go to the previous A10 firmware. (At least I don't think so anyway)
Melqui
Zen Master I
ronald1985
https://zentalk.asus.com/en/discussion/comment/117567#Comment_117567
https://zentalk.asus.com/en/discussion/comment/117562#Comment_117562
With RAW file, you can go to any version
ronald1985
Community Legend I
Melqui
https://zentalk.asus.com/en/discussion/comment/117577#Comment_117577
Hmmmm, I think you will lose data then.
That's what I think anyway because nowadays patch updates are incremental.
jfkeiuxje
Rising Star I
disable google play store then its goes back tp 1 ghz and 826mz
anjubunny123
Zen Master I
I am so lucky that I have read this issue in the forum before my system notified me for updating my Phone. Now I won't update my phone until it gets solved
