heat up while battery charging
jasonwch
Rising Star II
Model Name: ROG PHONE 2
Firmware Version: 17.0204.2007.27
Rooted or not: no
Frequency of Occurrence: always
i've posted this to chinese forum let me rephrase i english here and see if anyone can help.
While hypercharging with original Hypercharger and cable, i can feel the phone getting quite warm, as checked at Armoury Crate, CPU increase to around 5x degree celcius. As there is no battery temperature info so i cant tell what is the temperature of battery
Just want to know if this temperature range is normal? I didnt do anything while charging but turned ON, and the temperature went down after i unplug the cable.
ronald1985
Community Legend I
jasonwch
  1. Model Name: ROG PHONE 2
  2. Firmware Version: 17.0204.2007.27
  3. Rooted or not: no
  4. Frequency of Occurrence: always
With hypercharge, it is normal for the device to be warm when it is charging. It should cool down eventually.
When you can, can you indicate the temperature is showing on crate?
jasonwch
Rising Star II
ronald1985
https://zentalk.asus.com/en/discussion/34623/heat-up-while-battery-charging
will capture if i do HC later
Gustav_ASUS
Community Legend III
This is normal and your device temperature will peak around ~60%. It will cool off as it reaches full charge.
