10-09-2019 09:03 AM
10-17-2019 03:58 AM
10-17-2019 09:17 AM
abhishekgondkarAll ASUS products undergo intensive quality control, testing and inspections. The factory tries its best to make sure every product is perfect.I am also facing this issue on lower brightness.
@LP_ASUS I saw your reply that if this is a deal breaker then we should get it checked or return the device, but if this is a issue that most of us are facing (including you as well), can you update with root cause and let us know if this is a hardware or software issue and what are the probable solutions for it rather than just getting it checked or returning the device?
We love the device, but that does not mean you can imply "take it or leave it".
Do let us know root cause of the issue, log a bug, or let us know if this is an additional feature that you have given to us.
PS - I agree with @ag.954gupta, that the screen brightness is too high even on 0% brightness and IMO low on 100% brightness.
10-17-2019 09:19 AM
LP_ASUShttps://zentalk.asus.com/en/discussion/comment/21728#Comment_21728
This is most likely panel behavior. One possible solution given by R&D if you are concerned about panel quality was to adjust settings in Splendid. (Setting>Display>Splendid)
10-17-2019 09:21 AM
RAIDEN™You're in Splendid. I wasn't able to minimize the effect on my device, but adjusting color temperature and saturation may benefit some users.https://zentalk.asus.com/en/discussion/comment/21797#Comment_21797
Spendid where ?
10-17-2019 09:27 AM
LP_ASUSWell even on splendid the issue still persisit !! So they need to push an ota with the fixhttps://zentalk.asus.com/en/discussion/comment/21798#Comment_21798
