12-29-2019
03:35 PM
- last edited on
01-16-2024
01:46 AM
by
ZenBot
01-04-2020 10:55 AM
01-04-2020 11:08 AM
OPCI would rate this review 5 stars if I could. For now you get a like 😛I tried to replicate the situation with headphones. I use Bowers & Wilkins P5 headphones. The best way is to listen to Binaural recordings. And indeed the sound was mostly coming from the center and right. It can also be the choice of the musical studio which channel to record more. Then I tried some jazz music from a French singer Patricia Kaas. It didn't seem the right channel was louder, but more instruments were coming from the right. Then I choose a track with a solo classical guitar. The sound was coming from the center as it should. Then I chose a concert of classical music performed by London Philharmonic Orchestra. Those have the highest standard of recording. Again more instruments were coming from the right. The last test and one of the best to test channels was the Pink Floyd's composition called One of These Days from Meddle album. Here there is a clear transition of the keyboard sound originating in the left channel, passing over the center into the right channel. And there is a central beating part where sound should move in a circle. I know this track very well as I was listening it for years ona hi-fi setup through Philips professional studio headphones with 6 separate treble membranes and a separate bass membrane on each side. And indeed the sound generating in the left channel was a tiny bit lacking in loudness. That is before passing to the center it should have been a bit louder. I would say it's just a matter of balancing and maybe amplifying the left channel just a bit. I would also mention that the balance was best with headphones effects turned off. And the sound was more prominent to the right with headphones effects set to wide. I prefer to set it to traditional. All those differences are so marginal that most people wouldn't even pay attention.
01-05-2020 07:38 AM
julienvd93Thanks Julien! Music and photography/videography are my passions.https://zentalk.asus.com/en/discussion/comment/38444#Comment_38444
01-16-2020 07:45 AM
01-17-2020 12:29 AM
