11-13-2019 10:08 AM
11-19-2019 05:53 AM
LokiCan you please change the cable once more? There are so many tiny cables inside and it doesn't take much for fast charging to stop working. It could very well be that you have two bad cables. Also try and flip the the cable. A bad cable may still have fast charging on one side if you're luckyMy device is not fast charging
It just shows charging and it takes around 9hrs to charge
I tried with side port
Changed the cable
But to no avail
Is anyone else facing this issue?
Charging problem
11-19-2019 10:14 AM
Anders_ASUSI changed cable but still it remains samehttps://zentalk.asus.com/en/discussion/12976/charging-problem
12-03-2019 06:54 AM
05-30-2020 07:53 PM
LokiMine too. How's it now? What did you do?My device is not fast charging
Changed the cable
But to no avail
Charging problem
