09-20-2020 07:34 AM
09-20-2020 08:03 AM
jfkeiuxjeThe question regarding Huawei 40w Supercharger, it will probably burn your ports and fry the circuits as you are giving too much voltage than the original stated 30W which is why ASUS come with them and not 40W.Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Hey i have 2 questions i use Huawei 40w Supercharger Will ny charge speed increase with hypercharger on tog 2 and Will my screen on time increase with optiflex off
Charge and battery
09-20-2020 08:32 AM
09-20-2020 08:33 AM
jfkeiuxjeYou can use it but it won't charge at 40w. Maybe it will charge at 30w or at 18w depending on the charge config the charger has.Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
Charge and battery
09-20-2020 08:41 AM
ronald1985Dude do you have any idea what you are taking about?https://zentalk.asus.com/en/discussion/35976/charge-and-battery
On screen time depends on your usage of the phone as apps do not magically increase the battery juice for you. Optiplex helps you smooths things out for example playing games by removing the clunk/junk running the background.
