09-20-2020
07:34 AM
- last edited on
01-16-2024
12:43 AM
by
ZenBot
09-20-2020 08:50 AM
CatCanisterIf your phone is under warranty, then it is recommended to stay within the range. Otherwise, it would definately void your warranty if it does happen. That's where I am coming from. Stay safe rather than being sorry.https://zentalk.asus.com/en/discussion/comment/115060#Comment_115060
Dude do you have any idea what you are taking about?
Using charger with speeds higher than supported charging rates won't "burn or fry" anything. They just resort to lower speeds. LMAO you are to scare him or what?
I charge my Moto G8 Power with Asus 30w charger. G8 peaks at 15w. Nothing bad happens or happened.
Please speak only when you know. 😂😂😅😅😂
09-24-2020 02:17 AM
jfkeiuxjeYou ROG Phone II will most probably charge in 18W if you use that charger. Turning of Optiflex will probably not affect your battery life. It keeps commonly used apps in your RAM so that they will load faster. This is the main purpose with Optiflex. It might save some battery if you use an app that has already been loaded into the RAM but there are so many buts and ifs that I'd say that there's no noticeable difference in battery life no matter if you have it on or off.Please tell us some basic information before asking for help:
- Model Name:
- Firmware Version:
- Rooted or not:
- Frequency of Occurrence:
- APP Name & APP Version (If your issue relates to the app):
Hey i have 2 questions i use Huawei 40w Supercharger Will ny charge speed increase with hypercharger on tog 2 and Will my screen on time increase with optiflex off
Charge and battery
09-24-2020 04:11 AM
Anders_ASUSis it better i buy 30whttps://zentalk.asus.com/en/discussion/35976/charge-and-battery
