Camera zoom and exposure problem
KraKen
Rising Star II
Camera zooming problem
If i touch two times rapidly then swipe up or down then zoom some times doesn't working
Camera exposure problem
And if i pinch in or out on screen, then first exposure will increase or reduce then after zoom will work.
It is not perfect, we know that camera on rog in not good enough but i really wish to fix that problem in next update.
We can also use volume key to zoom in or out, then there is no problem with exposure, but sometimes clicking an image bt volume key is easier.
For that they should provide air trigger option for capture an image.
5 REPLIES 5
KraKen
Rising Star II
Anders_ASUS
I wouldn't recommend to zoom fast by pinching the screen while recording. You will find the same behaviour on ZenFone 6
If you want a nice, smooth and professional zoom then slide the recording button sideways. It's similar to using the volume rocker
Check this video
Sometimes zooming working and sometimes doesn't working while recording
