Battery Drainage
cb_arvind20
Model Name:ROG 2
Firmware Version:2009.49
Rooted or not:NO
Frequency of Occurrence:YES
APP Name & APP Version (If your issue relates to the app):Android system
For the past few days I have observed that battery drain has been abnormal.The main culprit is Android system.
I am down to 67% just from 2hrs of minimal usage.No games ,no battery heavy applications.This is really bothering me now.
10 REPLIES 10
Vableme
Rising Star II
That's the bad .49 build. Just download it from the rog site.
cb_arvind20
It looks like in safe mode it is doing ok as there are not many apps which I use frequently.
Clearing cache and storage for both Google Play Services and Google Play Store doesn't seem to having any effect
Aryan202
Community Legend I
Update to latest firmware then check again
cb_arvind20
Yes,it is up to date.It seems all I am left with is extreme option of resetting my Device.
Vableme
Rising Star II
Or it could be a battery problem.
