Asus Rog Phone 2 won't charge from bottom USB C port unless phone is restarted
krkaran12
I am unable to charge my phone from bottom USB C port , unless i restart my phone.
Once phone is restarted while connected to charger it detects charging from bottom USB C port.
But if i unplug and plug in again it is not detected
29 REPLIES 29
Try cleaning the port, i blew air into the port and cleaned the port, and it worked for me. It was having the exact same problem as i mentioned but it's behaving fine after i cleaned the port.
d3athp3ngs
This sometimes happens to me also, but now it charges but only as a fast charger. The bottom port won't Hyper charge even with the original charger and cable it came with. It also doesnt detect otg, usb, usb c dongle with earphones, and most especially my kunai and bumperr case. Anyone else have the same problem with the kunai and bumper case not being detected?
Kunai and holder works just fine with Bluetooth.
adrian_limindra
Mine also having same issue.
Asus the issue already open for months, do you already left the rog phone 2 just because you already launch the new rog phone 3?
vineethmohan902
How much cost for charging port rog2
vineethmohan902
@krkaran12 how much cost for charging port rog2
