10-20-2019
04:17 AM
- last edited on
01-16-2024
12:52 AM
by
ZenBot
03-05-2020 11:55 PM
LP_ASUShttps://zentalk.asus.com/en/discussion/comment/47350#Comment_47350
Rereading the post he quoted, I actually notated that as hardware because he can activate the Trigger by touching the back panel of his phone. Ironhide's problem is different.
LP_ASUSI too had the same issue. But it's like reduced now. I've even opened a thread for that.https://zentalk.asus.com/en/discussion/comment/47350#Comment_47350
03-06-2020 12:00 AM
LP_ASUSBut for me the sensitivity was making the problem it was actually making the triggers to work as described here.https://zentalk.asus.com/en/discussion/comment/47350#Comment_47350
Not all the issues have been the same in this thread. In the past, when we got logs from users where the sensitivity booster made no change to the Air Trigger behavior, it was hardware related.
03-13-2020 09:06 AM
03-13-2020 10:04 AM
ROGusergot same issue on my right trigger. if im playing Pubg is justike using single shot eeven you press more like burst shot. since i update my device.Ok. Please take this feedback as well: The right air trigger for me (on .35 version WW) is buggy. At times, it triggers with a pressure of 1or 2, at times it doesn't at all unless you press it to a 7 or 8, in which it lags to register the touch, triggers multiple times (1-2 bullets at a time, instead of a spray). I know it is a software issue, because when I try to touch the air triggers outside the gameplay/ in the lobby/ control settings (to key map the triggers), it works perfectly. This was not an issue prior to the update.
04-05-2020 07:08 PM
LP_ASUSHi, I'm having the same problem. Could you help me please?@ROGuser and @mr.strange I'd like to log your phones. I'll send you both PM's.
For anyone who is still having Air Trigger issues with sensitivity and is willing to provide a log, please reply in this thread and I'll send you the instructions as well. Thanks for your help everyone, we're working to resolve this as soon as possible for you.
