10-23-2019 11:05 PM
12-16-2019 01:12 AM
12-16-2019 03:31 AM
nightsilvanceYes, I have the same issue after the last upgradeExperiencing some issue with my right air trigger. Button press is sometimes unresponsive and intermittent. Notice it after the latest firmware update. Sometimes the button press would "flicker" when I'm holding it down. Want to know if it's a software bug or hardware issue. Hopefully someone can enlighten me.
Air Trigger issue
12-16-2019 10:03 AM
LP_ASUSASUS Service center confirmed that its a hardware issue and its with the faulty motherboard. My motherboard is being replaced and that should hopefully solve the issue as they say.https://zentalk.asus.com/en/discussion/comment/33271#Comment_33271
This is a similar but separate issue. If your Air Trigger is activating when you touch the back of the phone, that indicates a hardware issue and we recommend you visit a service center. I understand that you have already had the phone repaired, but if you are still seeing the issue you will need to have it repaired again.
12-16-2019 10:50 AM
nayyar.rahul18I'd like to log your phone in this case. If you're OK with creating a log for us to review, reply to this post and I'll send you a PM with instructions.@developers/Mods
The right air trigger has serious issues. I tried using them in PUBG for 4-5 hours continuously. The left AT worked like a charm while the right air trigger could never fire consistently for even 3 seconds. I have done all the nifty tricks like factory resetting/resetting/all possible change in settings in armory crate and pubg settings.
Can i do anything else now?
12-16-2019 12:25 PM
