10-23-2019 11:05 PM
11-10-2019 07:39 AM
11-10-2019 08:39 AM
nightsilvanceI have the same issue. The trigger is working perfectly if i remove the back case provided by them. Try removing the back case and play again.Experiencing some issue with my right air trigger. Button press is sometimes unresponsive and intermittent. Notice it after the latest firmware update. Sometimes the button press would "flicker" when I'm holding it down. Want to know if it's a software bug or hardware issue. Hopefully someone can enlighten me.
Air Trigger issue
11-11-2019 05:41 AM
nightsilvanceCould you check if enabling this (if the option is disabled) helps you.Experiencing some issue with my right air trigger. Button press is sometimes unresponsive and intermittent. Notice it after the latest firmware update. Sometimes the button press would "flicker" when I'm holding it down. Want to know if it's a software bug or hardware issue. Hopefully someone can enlighten me.
Air Trigger issue
11-11-2019 08:17 AM
11-11-2019 12:41 PM
