Charging Mode "Smart Bypass" ROG 9 Pro Edition
ShinRasetsu
Please have a Function that can Always Enable Smart Bypass in Charging Mode.
its a Pain in the ass to Always  Go to Settings to Just Enable it after connecting a charger, There is also an Inconsistency to the settings, in Game Genie it says the SmartBypass is Enabled but when you go to the settings it is not.
8 REPLIES 8
Exactly, either this or an auto turn on Bypass Charging, not to compare, but the rival of this phone already has auto turn on Bypass Charging, whenever the battery hits a certain percentage, Bypass Charging is turned on, so you don't need to keep going to settings. Hopefully they implement something like this soon
ShinRasetsu
What a Useless Software Update. Still Smart Bypass Can be Enabled Manually if there is a charger Attached. I dont know what is smart about this.
Current version
Update information
1.Updated Android security patch to 2025-07
2.Fixed an issue with abnormal key mapping behavior.
3.Improved Wi-Fi connection stability
4.0ptimized system stability
5.The default digital assistant app has been changed to Gemini, 6.Updated game profiles for the following games:
MapleStory Worlds (WW)、 Honkai: Star Rail (WW)(Cooler X Pro) Garena® Delta Force (TW)、 Delta Force (WW)、 Diablo Immortal (WW)(Cooler X Pro)、 Torchlight: Infinite (WW)、 PUBG MOBILE (TW)(Cooler X Pro)、 PUBG MOBILE (US)(Cooler X Pro), Free Fire MAX (WW), /F!J! -JLZ/ F/-
7.Updated AirTrigger profiles in ROG Instant Master for the following games: MapleStory Worlds (WW)、 Zenless Zone Zero (WW)(Cooler X Pro)、 Knives Out (TW)(Cooler X Pro) Knives Out (WW)(Cooler X Pro)、 GIRLS' FRONTLINE 2: EXILIUM (TW)(Cooler X Pro)、 GIRLS' FRONTLINE 2: EXILIUM (US)(Cooler X Pro)、 Once Human (TW)、 Once Human (US)、 Pokémon UNITE (WW) 8.Updated Macro profiles in ROG Instant Master for the following games: Honor of Kings (WW)、 League of Legends: Wild Rift (TW)、 League of Legends: Wild Rift (US)、 Wuthering Waves (WW)、 Arena of Valor (TW)、 Arena of Valor (US)、 Zenless Zone Zero (WW)、 Mobile Legends: Bang Bang (WW)、 Genshin Impact (WW)
ShinRasetsu
Smart Bypass Charging Must function As
Regular Charging when Device Battery is Lower than the User Pre Selected Charging Limit  example 80% then Enabled Bypass Charging After Reaching it. Very Simple yet ASUS Can't Implement it Correctly.
@ShinRasetsu I received information that this is indeed the case, if you pre-select a charging limit, the phone will automatically change to bypass charging when it reaches the limit.
This is exclusive for the phones with the bypass charge setting.
